Hi I asked about this problem before, after towing a trailer the shift lever doesn't move out of park when I depress the brake pedal and my brake lights don't work, i was told that a fuse or relay might have blown, so I was wondering where this fuse or relay would be so I can replace it. I had a quick look in both the in-car fuse board and the engine comparment one and didnt find any blown fuses. What am I looking for!!!help! Its a 3rd gen ssr-x. any help would be great. thanks
shift lever stuck
Originally posted by MattFHe still hasn't answered that since Gonzo mentioned it in the tech section.
I really hate multiple cross section posts.could it be the pedal switch itself.our sharran suffered from this and it was the actual pedal switch playing up from time to time,renewed the switch havnt had a problem since.
www.overfab.uk
my mates estima has the same problem... he plugged the light board in upside down and forced the plug... now some lights that didn't work before, do work and others don't work...
i couldn't trace a problem that night so i suggested ripping out and re-wire the towbar electrics and try again.nee nar nee nar, i'm a fire engine!
Originally posted by vatchmanhey matt you know them resistors..............Which, deviating somewhat, does lead to another question. Would this look out of place on the Surf?
Originally posted by northcountryboy76just trying to ask as many people as possible and get the correct answer as quickly as possible!! sorry it offends you!!!!It's just a niggle when it's already had a valid answer in the tech section.
Originally posted by northcountryboy76bulbs are fine by the way, had to go check them hence the reason I never replied to that question! so just wondering what the other options are?
