"Check the harmonic balencer!
Cheers for the info Tony, the pump impellor is shaft driven direct from the belt and is new so no probs there (I hope).
Block was OK and the bolts were torqued as the 4 runner 'cos the Surf aint listed on Autodata and the specs I found here were vague.
I hear you re the gas test and will get the Wurth rep to drop a testing kit in asap an test my coolant mud.
the effer
..The 1800 K petrol Rover engine
