HELP. PLEASE.... 3.0lt Cylinder Head removal problems...
Ok, I've spent 5 hours removing the various bits of my engine, but still have to remove intake, exhaust manifolds etc etc.
1)Can some one tell me how to remove the two bolts on the back of the head that hold the pipe bracket to the head. I've got 1 inch of room and can't even see the bolt heads.
2) How do I undo the exhaust manifold to turbo nut thats closest to the head? The other two are ok, but the nut is offset and you can't get a socket or spanner on it, also the pipe that goes from the top of the thermostat housing to round the back of the head is in the way. I can't move it out the way due to the problem above.
3) Is it possible to remove the head along with the intake and exhaust manifolds still attatched?
Please someone help????
