just thought i would let you know ive got the indicators working now.so theres no need to sort out the resistors.thanks for your help there buddy,really appreciated.it was the earth loop.wired them in and hey presto.
@fattf
that was lucky then.all i did was earth them out on the indicator loop and all was fine.funny how they dont work when grounded to the chassis.oh well never mind.they work now all is well.now if i can only get the hazards to work.once again thanks for the help matt.Originally posted by MattFGlad I just decided to check the forum. Was on my way to the P.O in a few minutes with the new ones.
Did they need wiring into a different grounding point then? Or have you done it a different way altogether?www.overfab.uk
That was a sneaky bugger then.Originally posted by vatchmanthat was lucky then.all i did was earth them out on the indicator loop and all was fine.funny how they dont work when grounded to the chassis.oh well never mind.they work now all is well.now if i can only get the hazards to work.once again thanks for the help matt.
Worked out well, though. These new devils would have been drawing 9A each.
If I manage to get hold of an old relay, I'll try and make you a new relay up that'll do the job instead of the resistors.
but should they break off or go missing then ill just get another set.
