Trying to help, I'll miss-quote brian ferry, I must be out of the in crowd!
'Dragging' rear wheels
OK so (retard mode on
) on me '95 manual surf it has normal gears on right & lever on left which has a button on side with 4WD on it & when pushed forward light comes on dash with 4WD on it i presume that is the L4 mode?
So if it's all way back with button in is that H4 & should there be a light on dash?
middle is netral it would seem.........
As i say seem to be midreading all that or sumin how do i get normal 4wd mode on for when it is seriously wet or as currently snowy?
Ta muchly
Si (AKA ignorant)[IMG]http://img.photobucket.com/albums/v44/scooby_si/Scooby_siSig.jpg[/IMG]
H4 is "normal" 4x4... L4 is 4x4 low ratioOriginally posted by scooby_siOK so (retard mode on
Ta muchly
Si (AKA ignorant)
you don't have the option of full time 4x4 (diff open) for road drivingnee nar nee nar, i'm a fire engine!
how u mean fine idea?
Amyway i'll have a play to see if it does actually come on with the button in once moving etc etc. Is there anything potentially wrong of it didnt light up in H4 but did in L4 mode?
Generally then at what point with on road driving is it safe or cunning to enter H4 mode. I know from my scooby owning days that it's the slowing down bit which is the main danger in icy type conditions so 4WD doesn't give you a licence to drive like a tw4t but anyway if there's any theories on when you like to hit the more power captain button speak now
Ta
Si[IMG]http://img.photobucket.com/albums/v44/scooby_si/Scooby_siSig.jpg[/IMG]
If you haven't got a gen 3 with an open centre dif then the smart time to go for 4wd on the road is when you can't go forward without using it! Using it while the wheels still have a fair amount of grip will promote undue stress within the transmission. In addition if you are driving at anything like normal road speeds you may find that you end up doing a bit of involuntary off roading as you take a trip into the scenery.Originally posted by scooby_sihow u mean fine idea?
Ta
SiParts of your engine go up, stop then go back! Mm!
