Originally posted by dabigman
'Dragging' rear wheels
Originally posted by dabigman4wd diff unlocked (for driving on hard surfaces) - 2H, lever in forward position but with with 4wd button pressed in
am I right in thinking that the 3rd gen can drive in this 4 wheel drive mode permanently on tarmac, or is it still liable to cause gearing probs, so preferable to stay in 2 wheel drive?
No, you'll be fine, you have a diff in the transfer case, to let the front and rear axle slip on cornering.Originally posted by Fieldsyam I right in thinking that the 3rd gen can drive in this 4 wheel drive mode permanently on tarmac, or is it still liable to cause gearing probs, so preferable to stay in 2 wheel drive?
Just uses a little more fuel.
yeah, you can drive like that all the time but you'll still get stuck in anything slippy as all the drive will be transferred to 1 wheel... it's good for snow and ice ans you don't have to keep changing to drive over the bits of bare tarmac.Originally posted by Fieldsyam I right in thinking that the 3rd gen can drive in this 4 wheel drive mode permanently on tarmac, or is it still liable to cause gearing probs, so preferable to stay in 2 wheel drive?
works the same as a permanent 4 wheel drive motor.
the diff lock is in the transfer case and locks the 2 props together so that you get drive to at least 1 back wheel and 1 front wheel.nee nar nee nar, i'm a fire engine!
RE Manual Trannies
Newbie here. The H2 to H4 and vice versa stuff above applies to a 2nd gen 4runner with its non-electric transfer case, which is different to a 2nd gen surf which has a button on the side of the shift lever.
According to the stuff above, if I wanna move from H2 to H4 then I just get my speed under 50mph and move the lever
The lever on a 2nd gen reads L4 on top of H, get what I'm thinkin?? According to the 'stuff above' shifting into low range needs 5mph tops!
Is this right so......
2nd gen surf:
H2 to H4: Speed under 50mph, hit 4wd button, see 4WD light on dash to confirm
H4 to H2: Any speed, hit 4wd button, see 4WD light go out
H2/H4 to L4: Speed under 5mph, no acceleration, depress clutch, shift lever
2nd gen 4runner:
H2 to H4: Speed under 50mph, shift lever to H4, see 4WD light on dash to confirm
H4 to H2: Any speed, move lever, see 4WD light go out
Does depress mean floor the pedal or dont floor the pedal???
This thread is part of the FAQ section and I think its worth clearing up (for me
Matt, you mentioned this diff-lock, well I've looked everywhere - I can't find this diff-lock thingy - so where's it got to?
And Tony, I'm only getting 23.5mpg is this right?
If I not got a diff-lock, can I get one - and from where?
Oh look, I've found a little red button - is that it? ay ay ay ay
you can tell it's friday ayDave
You won't have a centre diff lock, it will be locked as soon as you change to 4wd. Only 3rd gens have the option of and open centre diff for 4wd on "good" surfaces and a closed or locked diff for bad or loose surfaces. If you use 4wd and a locked centre diff on a good surface the front and back wheels will all be turning at the same speed, which is not good when turning a corner as the back wheels will take a slightly shorter route which means they need to be going slower. Solution tyres break grip, likely in the wet and going fastish so you end up having a quick off road expedition into the scenery, or transmission "winds up" and maybe goes bang.
The other diff locks you may have will be on the rear axle to lock it side to side. These are limited slip diffs, and probably dont work anyway by now!
The red button is so you can get it out of drive without turning the ignition on and putting foot on the brake.Parts of your engine go up, stop then go back! Mm!
Err - ta very muchOriginally posted by TJGYou won't have a centre diff lock, it will be locked as soon as you change to 4wd. Only 3rd gens have the option of and open centre diff for 4wd on "good" surfaces and a closed or locked diff for bad or loose surfaces. If you use 4wd and a locked centre diff on a good surface the front and back wheels will all be turning at the same speed, which is not good when turning a corner as the back wheels will take a slightly shorter route which means they need to be going slower. Solution tyres break grip, likely in the wet and going fastish so you end up having a quick off road expedition into the scenery, or transmission "winds up" and maybe goes bang.
Dave
