matt ive fixed the tardis.
  • #31
    Originally posted by MattF
    My aircon rad has a forcefield around it. Least that's the conclusion I've come to.
    Generated by THE WRATH OF WIFE
    www.daemon4x4.org
    • #32
      you need to borrow my sonic screwdriver.
      www.overfab.uk
      • #33
        Her Id? protecting it. (Forbidden Planet).
        • #34
          • #35
            yea in fact stein is better than ever,i ran through all the rocker gaps.most of them shall we say were a little out,warp factor nine scotty.
            Nice. Bet you must have been chuffed as 'owt when you found out that's all it was. Was it just due to settling as he's bedded in then?
            • #36
              thats easy to solve,give her a copy of womens own and when her mind is distracted smash the rad with a hammer.sorted
              www.overfab.uk
              • #37
                • #38
                  yea,chuffed as nuts.i had visions of a major strip down a rebuild,should of known better really.the tappets are normally hydraulic,but because the engine was lightened and balanced,it would rev higher.under these conditions hydraulic tappets make the valves bounce,so solid lifters and roller rockers were fitted.hence having to adjust them every now and then.
                  www.overfab.uk
                  • #39
                    It's nice to know he's okay. It's always the simple things that bite you.
                    • #40
                      hes back fighting fit,just hope your mrs dont get hold of him, charge ,run away
                      www.overfab.uk
                      • #41
                        This thread only needed one reply, and that was from Matt, the person that it was for the attention of !!!!!
                        • #42
                          matt have you read back through some of these posts ,were talking about stein like hes some kind of person,pmsl
                          www.overfab.uk
                          • #43
                            Sshhhh. He'll be offended if he hears you saying that.
                            • #44
                              look out vince is doing his hall monitoring bit.
                              www.overfab.uk
                              • #45
                                I've just noticed Vince. Whereas I've become the spell checker, you've become the post counter.
