Tailgate motor
  • Tailgate motor
    I am a muppett
    I cant believe that I posted wiper motor its actually tailgate window motor I need.
    In my defence I was P****d off and it was chucking it down and cold
    Hope u can help
    Steve
    Originally posted by Stevie the Pieman
    I am a muppett
    Hope u can help
    Steve
      front passsenger side door motor from a corolla etc
        Are you sure it's the motor ,not relays etc .
        Try doing a search , It's quite a common problem
          I am a muppett
          Hope u can help
          Steve
          As Benson said, are you sure it is the motor???
          Will the window atempt to go up/down??
          Are there any clicking noises???
          If you get really stuck I'm only in Newcastle under Lyme, have replaced motor/regulator assembly on mine and can now get it all out in a record time
          Any probs gimme a shout
          NO WORRIES!
          Rusty
            Loadsa relevant stuff on here http://www.geocities.com/dkwalker/4runner.html
              I replied to your previous post and said the same as above. Check the motor mate. Easy to give it 12V off the battery and see if it turns.
              If anyone has a duff relay board, I would be interested in doing a post mortom on one and seeing if it is viable to recondition them, with uprated relays. Hot soldering iron and test gear at the ready.
              It's only a hobby!
