Grayston wheel spacers
  • Grayston wheel spacers
    Are they any good?
    They seem to be a big name in wheel parts, but their spacers seem a little, erm, cheap compared to roughtrax. (£30 a pair for 30mm)
    you got a link to them??? they sure are cheap.... suspiciously cheap
    TeaM BOFA4x4 Mac 2008
    www.bofa4x4.com
      Originally posted by Apache
      Are they any good?
      damn !!! i hope there bad
        If there them so called universial ones then there no good, not safe!
          Don't look good to me.
          http://www.graystonengineering.com/wheelnutmenu.htm
            http://www.graystonengineering.com/shim&spacerpage.htm
            the ones right at the bottom of the page look better than some of the ones higher up, but i know nothing.
            =SOLD UP!=
              Other than 'dont look good', or 'not safe', any info to back that up? Just begrudge spendin extra cash without reason. Happy to go the Tony N or Roughrax route for a sound reason though.
                There is a 'I lost my wheel' thread that used cheap spacers
                www.daemon4x4.org
                  They come with 'extension studs' need I go on?
                    Using my non-technical mind, this thread says not to use the bolt-through type and these appear to be those with either the choice of longer bolts or 'stud extensions' which would terrify me to start with.
                    But I may have misunderstood somewhere.
                      OK, nuff said!
                      How do the Roughtrax ones work then?
                        OK, nuff said!
                        offset studs
                        www.daemon4x4.org
                          OK, nuff said!
                          You bolt them on to the hubs, then bolt wheels on to them - hence normal loading on the studs rather than twice.
                          Do pay attention
                            Do pay attention
                            I know! I brought the subject up in the thread you posted too! Still, it was August and my brain was probably overheated.
                              Another IOTW nomination
                              www.daemon4x4.org
