Rear window.
  • Rear window.
    Hi, can any one help. Rear window goes down no problems. Got slower and slower to go up now eventually stopped 3/4 up. Had to manually encourage window to go up. If the motor is removed (assume this is the problem) is it possible to close rear window manually i.e. what stops it from slipping back down.
    look here for a start
    http://www.hiluxsurf.co.uk/forums/showthread.php?t=5178
    www.daemon4x4.org
      hi mate, mine was the same and i replaced it with the window motor from the nearside rear window motor. both work fine as the back window is heavier so the old motor has enough life left in it for the door window.
      http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=30271
      heres a thread on how to remove the rear window motor. not too difficult mate. either swap it or get a new motor.
      worth greasing the hell out of everything metal to metal as well
      TeaM BOFA4x4 Mac 2008
      www.bofa4x4.com
        Rear Window.
        No problems getting motor out just need to shut glass and leave while I investigate motor. Working on front drive with no garage.
          im in the same situation mate, thats why i swapped them over.
          www.bofa4x4.com
            Try just cleaning and lubricating the window rubber channel first. There's a good chance it's just gunged up and sticking.
              I had this..
              window goes down but strugles back up...if you help it up as it closes all works fine.
              Then over time it stopped working.
              Searched the forum and somone said it was a rubber bush inside of the motor.
              All I needed to do was remove motor and open up the round plate on it. Put three self tappers into the rubber bush and the cog it had come unstuck from.
              Works like a dream now.
              If you need more detail I will post a thing with pics
              Mark
                Having got the window motor out
                Remove the plate by gentley prising the metal tabs of either side
                If the rubber bush has come apart then.....
                Counter sink the plastic cog to allow for the heads of the screws (1 in pic) (2= the exsisting holes) then drill and self tap the metal bit the rubber was attached to.
                Then screw both bits together (ruber and metal) and then joins all together blue= rubber bush red = metal plate yellow = plastic cog
                And replace back in motor.
                Job done 30 mins and 1hr to take and replace motor
                Cost = 1.5 hr and three self tappers
                Mark
                  Rear Window.
                  Cheers guys, I'll have a go when I finish my 101 other jobs. You know, wife, kids, work etc.
