Just bought a 1996 SSR-X imported from Japan. Everythings fine apart from the CD player.
Now I know the radio needs a band expander so that is not an issue. However the CD player just rejects the CDs as soon as I insert them. I spoke to the garage about it as it is still under warranty and he stated that the CDs are also a different format, but that copied CDs may play in it but not shop bought ones.
Is this right or is he feeding me a line?
Anyone else had this problem?
If you have a lens cleaning cd, pop it in. The type where you put the fluid on the little brush on the underside of the disc. Try it a couple of times. If that makes no difference, just replace the whole unit with a standard one.
, I've seen fewer switches on an aeroplane flight deck. Very impressive though
