is it possible to get the 3l auto to lock into 2nd so it doesnt start off in 1st, or change down when the revs drop
auto lock into 2nd
Short of removing 1st gear from the box..........NO!Originally posted by iainanderson924is it possible to get the 3l auto to lock into 2nd so it doesnt start off in 1st, or change down when the revs drophttp://www.apspropertyfix.co.uk/
in 2, it will still start off in 1st, just won't go into 3Originally posted by stormforce1067if its just for off road use just put it into 2 on the selector and press the 4wd button if you think you need it or the L position and then the 4wd button when needednee nar nee nar, i'm a fire engine!
yea smithy heheheheeh
had an afternoon at glentarkie, just sos i dont ambarrass myself
for those others, being able to lock into 2nd can give you a better engine torque to surface transmission, good for steep ascents, you can do it with 3l auto but you have to gun it to get it to change up, then you can back off a bit. If it gets tricky, the tranny will change down to 1st and its likely the tyres will then slip due to too much torque /not enough traction.
answer would be fully locking diffs instead of the limited slip ones. I had also thought about 1/4 ton of sand over back axle.... anyone tried that?
Oh by the way, surf defended its honour admirably against all the centre landies
