Originally posted by Gizmo
Couple of PC questions
All you need is the IP address(es) assigned by the ISP... do what you want inbetween the double hop... then hard code what you have to and DHCP what doesn't have to go out and mask that set through the internal gateway. Or even step these DHCP assigned addresses out inside the double hop dmz...?
Originally posted by AndyLalaAll you need is the IP address(es) assigned by the ISP... do what you want inbetween the double hop... then hard code what you have to and DHCP what doesn't have to go out and mask that set through the internal gateway. Or even step these DHCP assigned addresses out inside the double hop dmz...?
Originally posted by AndyLalaStill got me a mention in dispatches for getting an app to work in an environment that would never support it. App manufacturer was also real surprised.
