Couple of PC questions
Originally posted by MattFSo you've setup your login username and password on the Linksys? When you plug it into the phoneline, is the Linksys router itself establishing a connection okay with the ISP?
Yes.
No.
All the indicator lights on the Linksys that supposed to be lit, are (green) but the light that says 'Internet' lights up red. No-one mentions a red light on the help pages/forums, so I don't know wether it's supposed to red or green when connected.
Both the laptop and desktop won't connect, I get the box that says 'no dail tone'
The laptop connects to the modem/router but not to the internet.
Originally posted by BUSHWHACKERYes.
No.
You are disconnecting the USB modem from the phoneline, aren't you? You shouldn't be getting a message saying no dialtone. The Linksys unit sees to that, and keeps it invisible from the machines. Try uninstalling the Tiscali connection software from your PC. Sounds like it is still trying to use the usb modem as it's default route.
If you goto the setup pages on the Linksys, there should be a status page on there that tells you if the link with the ISP is established.
MattF,
As regards your e-mail forwarding query, can you not add the original e-mail as an attachment to a new clean mail? I get this in work all the time.
Within thne new mail window you need to use "insert/item", then scan down until you find the mail you want (presumably in your inbox) and double click insert it. That should put the whole message in there as received and the recipient only needs to double click on the message attachment icon to open the original message.Mike G
Try looking at this.. saves me typing it all out.Originally posted by MattFFirstly, might any of you M$ chaps know how you can get Outlook to forward an e-mail with all the original header info intact?
http://micro.uoregon.edu/fullheaders/#outlook
I cant try this for you as I am on Office 2007 and the GUI is different.
It looks like you have the modem/router issue in hand ;-)-=I swear to drunk I'm not god=-
Cheers chaps. Trev helped me test the attachment method, and that one worked a treat.
Finally managed to catch one of these mails on the server today as well. Why is it that when you specifically want something to happen, it never usually does?
Taken me ages to collar one on there.
Cause of the problem is some pillock of a company that is breaking just about every rule with regards to a smtp session.
1) Invalid helo. They're sending an unqualified name in the helo.
2) Sending from a smtp server with no A or PTR record.
3) Setting the recipient address as the sender address with no prior authorisation for a restriction bypass. Spoofing the sender address instead of doing it properly.
Is it just I, or do some companies, who should know better, not have the faintest idea what a network truly is? Numpties. They pull a trick like that and then wonder why mail is being rejected. Yeah, right.
Matt!! forgive a question from a thicko but is what you were asking similar to what i wanted to do, post jokes my nipper emails to me on the jokes forum?
I tried allsorts of fiddleing about but it wont work, i give up asking him to help me,Too young to die and too old to give a toss
To do that, you should just be able to highlight the text in the e-mail, right click and the select copy, then in the forum message box just left click in there so you can see the blinking cursor, right click and then select paste. Should copy all the text in that you selected.Originally posted by ian619Matt!! forgive a question from a thicko but is what you were asking similar to what i wanted to do, post jokes my nipper emails to me on the jokes forum?
To highlight the text in Outlook?, just press and hold the left mouse button at the start of the text you want to copy, then move the mouse cursor to the end of the text you want to copy, whilst keeping the left mouse button held down, then let go of the button.
Originally posted by ian619Yep done that, and it did'nt work, plus some of them have picture attachments, i'll keep fiddleing
With the attachments, if you right click on those and 'Save as', you can save the attachment to your desktop, or wherever. You can then upload those in the attachment bit when you're doing the post. Not sure why the copy and paste ain't working though.
Secondly, ADSL routers. Might anyone have a recommendation as to a good ethernet ADSL modem that allows the same gateway I.P to be assigned to both the internal and external interface without throwing a wobbler? Conexant have removed the ability, so their chipsets are a no-go, and the Linksys ones were iffy last time I checked. D-link is also a non-starter. (Hate their weird random lockup problems). Has to be a proper static setup as well. Half bridge option is no good due to it's insistence upon using DHCP and the firewall controlling several static I.P's.
Cheers.
Cant guarantee it but have a look at Zyxel. Failing that your going to have to possibly stump out quite abit and go looking at the CISCO stuffLast edited by Gizmo; 20 January 2007, 21:53.Gaz
That wouldn't stop the router requiring two IP's, though, would it? What really annoys me about it is the fact that even the cheapest of routers have had this ability previously, yet suddenly a large percentage of manufacturers seem to think the functionality is no longer required. Bridging/spoofing shouldn't be this hard.Originally posted by AndyLalaHow about this...
NAT across the DSL router.. then NAT back to the original IP across the firewall (double Hop)... something we played around with recently to fool a gateway that was just too intelligent for its own good.
