How many switches are supposed to be illuminate once you've turned your lights on? The only one that lights up in my Surf is the drivers electric window switch and that's about 1 candle power! The heated rear window switch only lights up when it's on.
I've installed a couple of blue LED clusters to shine on some of the switches as they were a bugger to find in the dark.
It's the only downside I can find with the Surf, nothing that's illuminated is very bright. I've fitted the blue LED bulbs for the instument cluster which helps but it's only bright where the bulbs are located, the surrounding area is still dim.
I've seen white dials on eBay with their own lighting advertised for around £48. Has anyone fitted these, or similar, and are they much brighter than standard?
Thanks guys.
'Copycat' (the artist formerly known as kameeleon).
Thanks guys.
