rear springs
    Originally posted by j.hell
    will i need new shocks with this or will mine be ok & how do you wind up the torsion bars
    They will fit with toyota shocks ..........But its worth checking if they are ok or leaking before you do the work ......Best place for shocks is Tonyn as you'r in da hood
    www.daemon4x4.org
      if you can weld then then you can lengthen your panhard rod by cutting and welding it.
      TeaM BOFA4x4 Mac 2008
      www.bofa4x4.com
        Originally posted by stormforce1067
        vince wins by a minute
          i have s.a.s and was thinking of getting the rear springs off roughtrax which say they have a 2" lift which sounds good but how do i lift the front to match and is there anything else that needs to be done i.e brake lies e.t.c
          thanks
          Your cheapest option is Milners 20% stronger springs. The front is lifted by tightening the torsion bars. Easy to do with the correct size spanner.
          Just jack up the front wheels and tighten the adjusting bolts which are found underneath the truck (one at each side) about midway the length of the truck.
          Going this route nothing else has to be done. :
          Hope this answers your questions.
          Trust your Hound.
            Originally posted by joker??
            Vince wins by a minute
            i know i just couldn't be bothered to delete it
              tell them they look gay
              what you mean tell them they are going to be put on a 3rd gen
                thanks for the info peeps and if i go the budget way is it still going to be ok for going off road
                  Yes and heres where the torsion bar bolts are (kindly sent to me by laserjock a while back)
                  Trust your Hound.
                  • #24
                    took mine down to cornwall [offroad] bog standard even semi bald road tyres didnt even get stuck did i richard ??
                    • #25
                      YES
                      • #26
                        no you never did you Dave but i did twice in the same place and you towed me out
                        • #27
                          hehe sorry for bringing it up AGAIN richard
                          • #28
                            i did get stuck a third time when i was balanced on the hump up on the track
                            • #29
                              why were you humping the track richard?
                              www.overfab.uk
                              • #30
                                you know what us Cornish are like..
