rear springs
  • rear springs
    i have s.a.s and was thinking of getting the rear springs off roughtrax which say they have a 2" lift which sounds good but how do i lift the front to match and is there anything else that needs to be done i.e brake lies e.t.c
    thanks
    thanks
    No they fit strait on and give a instant 2" lift ....But if you carry alot of load in the back they will not last
    The general rule is Milner standard springs , + 2" procomp es9000 shocks and 2" coil spacers..........OR if you want 5" of lift see bushwhacker
    www.daemon4x4.org
      thanks
      SAS = solid axle swap - one of the more extreme mods anyone can do to the front of their truck (lift = 6''ish)
      If you have SAS why are you asking about front lift?
      LC springs from Milners will give 3'' lift.
      EDIT OOOOOOPS = sas = saggy ar5e syndrome - ever so sorry - me get back to the wine .............
      Another member of the 'A' team
        Saggy Ar%e Syndrome
        www.daemon4x4.org
          Originally posted by Woodzie
          Saggy Ar%e Syndrome
          Arse!
            thanks but i didn't want to spend to much doing it but i do need new springs though
              cheapest option is the 3inch rear lift 2inch front lift combo. its hdj80 landcruiser rear springs and you can wind the front torsion bars up 2inches for free!
              44 quid +vat from milners
              if you lengthen the springs good idea to put longer shocks on. i have +4 rears and +2 fronts. binned both anti roll bars for better articulation off road
              TeaM BOFA4x4 Mac 2008
              www.bofa4x4.com
                just go for the milners 20%stronger springs item no.004014 £44 per pair + p&p +vat
                  thanks
                  dont go the roughtrax way had there springs on my truck sas within 11 months no weight carried in truck [no jokes about val ]
                  go milners with jotto spacer or lc springs,
                    Go for milners 20% then as the springs are cheaper than roughtrax
                    And one of their better products
                    http://www.milneroffroad.com/LN130.htm
                    www.daemon4x4.org
                      If you want a 3" lift on the rear, then you'll need Landcruiser springs from Milners @£44.
                      A pair of rear shocks from Procomp or TonyN @ £80.
                      A panhard rod and anti-rollbar drop brackets complete with various nuts and bolts from me @ £47.
                      No need to alter/lengthen any brake lines, and just adjust the torsion bars on the front.
                      If you don't want to be so radical, then a pair of up-rated springs from Milners @ £44. is all you need.
                        will i need new shocks with this or will mine be ok & how do you wind up the torsion bars
                          http://www.off-road.com/toyota/tech/torsion/index.htm
                            tell them they look gay
                              take a look here http://www.4x4wire.com/toyota/tech/torsion_bars/
