when you press the clutch down you are disengaging the gearbox,so this sounds like a gear box prob, if they didnt line up the clutch propely they would have had differculty getting the box back in and the way cowboys overcome this is by pulling the box in by the bellhousing bolts this can fu damage the first motion shaft bearing, i hope its not the case, to rule out the thrust bearing get someone to move it away from the pressure plate by the clutch fork and see if the noise goes, hope this helps in some way.
Not happy...Nationwide Auto Centre!
Ironic that you say that, I think that is what's happened!!!Originally posted by terry edgleywhen you press the clutch down you are disengaging the gearbox,so this sounds like a gear box prob, if they didnt line up the clutch propely they would have had differculty getting the box back in and the way cowboys overcome this is by pulling the box in by the bellhousing bolts this can fu damage the first motion shaft bearing, i hope its not the case, to rule out the thrust bearing get someone to move it away from the pressure plate by the clutch fork and see if the noise goes, hope this helps in some way.
Exactly, same here, apart from the ex BMW techi, I just employ me!!Originally posted by AuldNickNever EVER use a main street garage, these guys are never time served, have massive targets to meet and fat bonus's to gain.
I employ a time served BMW techi, I charge £30ph yet most local BMW muppets insist on gettin humped by the "real" dealer paying 4x my hourly rate 'cos his workshop has a fekin carpet???!!!!!
I've come to the conclusion that a lot of customers feel they are getting something extra if they get shafted four times as much. Being honest and truthful doesn't seem to register with a lot of them. Shafting them for cr@ppy work does. I'll never understand customers logic.Originally posted by TonyNExactly, same here, apart from the ex BMW techi, I just employ me!!
I have a close uncle who wont use my garage, he insists on using the largest non spec dealer in the area (Arnold Clark), his last "service" cost £220 + VAT which as far as I could see consisted of a oil & filter change on his 4 year old Kia!!!!!??Originally posted by MattFI've come to the conclusion that a lot of customers feel they are getting something extra if they get shafted four times as much. Being honest and truthful doesn't seem to register with a lot of them. Shafting them for cr@ppy work does. I'll never understand customers logic.
a neighbour next to my garage would insist to use main dealer because he wanted his service booked stamped by fords, after his last service £220 he came to me because a warning light was on,turns out his master cylinder had been leaking for a long time and they didnt notice,checked to see if they had serviced it, all they had done was an oil and filter change,it had old plugs,air filter etc he complained and they fitted a master cylinder free of labour "wow" and a free service that he had already paid for,work that one out?Originally posted by AuldNickI have a close uncle who wont use my garage, he insists on using the largest non spec dealer in the area (Arnold Clark), his last "service" cost £220 + VAT which as far as I could see consisted of a oil & filter change on his 4 year old Kia!!!!!??JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
