I keep getting mud in the back door lining, around the wheelarches (no the plastic hasn't warped in the summer heat! ). Anyone else had this problem and/or worked out a cure? (apart from buying a 2ndGen! )
Mud in me doors!
is it on both sides of the surf or just the one...if it's both then maybe its a design flaw!
you may be the only 3rd genner who actually goes through mud, so you may not get too many replies...
i'll stop now!i swear, it was like that when i got here...
Originally posted by Ace PikerMethinks you are missing the point of a 4x4!http://www.apspropertyfix.co.uk/
Originally posted by LeodisMaybe its because hairdressers dont normally go offroad.
but it's normally in an mx5 while doing their make-up in the rear view mirror and the offroad is the grass verge next to the motorway.i swear, it was like that when i got here...
Originally posted by Ace PikerI keep getting mud in the back door lining, around the wheelarches (no the plastic hasn't warped in the summer heat! ). Anyone else had this problem and/or worked out a cure? (apart from buying a 2ndGen! )PERFECTION.
Try using duck tape to seal up the lining's.If the puddles to deep..LEARN TO SCUBA.
Originally posted by sumoNope I dont suffer from mud getting in my rear door lining's,mainly cos mine is a 2 door 1st GEN.....dont you just lovePERFECTION.
Try using duck tape to seal up the lining's.Nil illegitimi carborundum
