Hello there, i'm thinking about flleeing the ranks of the green oval cos i'm fed up of being cold wet and having bits drop off. Im looking for a bit of comfort and some jap reliability! Just wanted to know if there are any major problems i should be looking out for other than the cylender head and rear window. Also, what size tires can i run on a 2" suspension lift?
Buying advice
Have a read hereOriginally posted by monkeyallanHello there, i'm thinking about flleeing the ranks of the green oval cos i'm fed up of being cold wet and having bits drop off. Im looking for a bit of comfort and some jap reliability! Just wanted to know if there are any major problems i should be looking out for other than the cylender head and rear window. Also, what size tires can i run on a 2" suspension lift?
http://www.showmesome.info/hilux/info/faq.htmwww.daemon4x4.org
With a 2" suspention lift you can only run 31x10.5x15, but if you did a 2" body lift as well you can run 33x12.5x15.Originally posted by monkeyallanHello there, i'm thinking about flleeing the ranks of the green oval cos i'm fed up of being cold wet and having bits drop off. Im looking for a bit of comfort and some jap reliability! Just wanted to know if there are any major problems i should be looking out for other than the cylender head and rear window. Also, what size tires can i run on a 2" suspension lift?I'm a custard donut monster
rear window can be easily swapped for the passenger side rear window motor mate, a no cost fix. just done mine and it works a treat. and the motor from the rear has enough life left in it to move the lighter side door window.
more expensive mod parts that landys though.
TeaM BOFA4x4 Mac 2008
www.bofa4x4.com
he got it relisted now with a buy it now of £2000
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=180059816968https://www.facebook.com/groups/henpals/
