Sanor horns
    Christ. They must be a foot long. What are the trumpets. About 6" and
    8"?
      1 is 15" long and the other is 13" long with a 7.5" diameter mouth on them but think of the fun you could have with them
        No one will ever be able to say they didn't hear you. Could be amusing at
        a level crossing.
          a level crossing.
          especially when you get the little scrots messing around the level xings
            Nice pair Richard, are the other's the same size?, would'nt like to be standing in front of those when they go off, Your gonna need a roof bar just for the horns Hope you can sort out a comp for em, I'd imagine the air con pump could handle enough pressure as long as you give it a little time to charge an air tank, similar set up to truck air brakes, People are gonna $hit themselves when you press the button, Fantastic
              Originally posted by ian619
              Nice pair Richard, are the other's the same size?, would'nt like to be standing in front of those when they go off, Your gonna need a roof bar just for the horns Hope you can sort out a comp for em, I'd imagine the air con pump could handle enough pessure as long as you give it a little time to charge a air tank, similar set up to truck air brakes, People are gonna $hit themselves when you press the button, Fantastic
              yea the other 2 are exactly the same.I was looking on the internet for them and although they are made from cast alloy they are meant to be black(the best color) so i might just give them a good clean and respray them black again.The other pair i may do the same and then sell them.
                Those Scotchbrite pads are good for removing surface oxidisation on alloy.
                BTW Ian, 'nice pair'? I'm getting worried about you two.
                  I'm sure i dont know what you mean
                  Fit all four of em Reccon if ya set em off with the truck in netural they'd blow it backwards, How much do ya think they'll fetch if you sell em.
                  (you can tell what i'm thinking here cant ya)
                  • #24
                    the compressor only has to be small... pump it in to a reciever with a pressure switch to cut out the compressor when pressure is built up.
                    unless you're gonna having prolonged horning, then that should do.
                    and the horns are about £150 for the genuine inter city ones
