seems like i may have a small leak on my diff after the weekend at norfolk so it looks like tomorrow may have to check on level and top up, what diff oil do i use and will i be able to use it on the back as well ?? cheers
Diff
On top of the diff is a small breather cap. Check that isn't blocked after the trip or that will cause diff oil to leak out when hot. The other thing to check is that no water has got in the diff via the breather cap- as that may have same effect.Originally posted by joker??seems like i may have a small leak on my diff after the weekend at norfolk so it looks like tomorrow may have to check on level and top up, what diff oil do i use and will i be able to use it on the back as well ?? cheers
Find a straight road, stick the car in 4WD for a bit to churn it up (don't use 4WD on bends!). Then drain some off to check for water content. If emulsifed drain fully and re-fill with fresh Hypoid Gear Oil._________________
Nevillef
Do 2nd Gens have limited slip diffs like 3rd Gens?Originally posted by laser_jock@workIf emulsifed drain fully and re-fill with fresh Hypoid Gear Oil.
If so, make sure the hypoid gear oil has the LSD additive.
Castrol do a Hypoid LS90 gear oil & Comma do a semi-synthetic 80W/90 for LSD gear oil which is the one that I used, as it was easier to find than the Castrol.
If you go to a Toyota dealer they can get the Castrol but only in 25 litre drums. Comma supply it in 5 & I think 1 litre bottles & is available from most motor factors.
Comma I think are part of the Texaco group, so the oil is good quality.
hope that was not because I led the way, better check mine!
