ARB looky likey
    normally takes me two goes with most DIY things!! which is why i call in me dad - he cut me out a perfect bit of chequer plate to go on the drop down part of the tailgate - it fits like a glove, now if i had done it, now that would have been a different story, gaps everywhere on first attempt and alot of swearing etc
    Bunkle
    Fox Hunting is Dangerous
      hey,we all got to start somewhere,we all get a visit from the fcuk up fairy at some point.me i get regular visits.
      www.overfab.uk
        If you think getting your dad to do it is bad, I seem to remember someone
        getting their girlfriend to butcher the bonnet.
          would that be andy by any chance
          www.overfab.uk
            Best way to mark out the hole in the outer wing is to masking tape the wing and then tape the foam gasket to the wing when you know where you want it and and draw the holes on the masking tape you put on the wing first and you will have the shape of the hole the snorkel goes through and the bolt holes . You need the holes slightly larger then the bolts and snorkle for clearence , so a little mishap wont show . Make sure you paint the exposed metal to prevent rust .
            As for the inner wing , thats different , good luck with that one .
                Cutting holes in wings
                http://www.hiluxsurf.co.uk/forums/sh...t=guess+making
                www.daemon4x4.org
                  daaaaaaaaaaaaaaaaad
                  Bunkle
                  • #24
                    Sorry for not posting the pics - I took some with my mobile and they were rubbish - I'll hopefully get some better ones today
                    Roger
                    • #25
                      cheers - whenever you get the chance - much appreciated
                      Bunkle
                      • #26
                        Shouldn't that say two incorrect door cards?
                        You can fcuk off. I'll find a use for them.........
                        • #27
                          • #28
                            Pics as promised - hopefully you can see what you need. If you want any more detail let me know as hopefully the bumpers going back on at the weekend
                            Roger
                            • #29
                              fantastic - exactly what i needed - this shows me how to attach the blighter - thanks again,
                              Bunkle
                              • #30
                                If i've interpreted the pictures right,
                                1. Fit's onto front crossmember? Bolts through the two large holes on the front? (and any underneath?)
                                2. Goes under the chassis rail and bolts up into the chassis rail in 2 or 3 places?
                                3. Bolts to original bumper mounts?
                                Can someone either confirm or correct please? (or just tell me to get back in the cupboard and not be so stupid)
                                =SOLD UP!=
