FAO anyone running a V8
  • FAO anyone running a V8
    I sort of got offered a 3.5l rover v8 last night, for the cost of removing it from the vehicle it's in. I can almost certainly remove the engine without too many problems anyway.
    A few questions about putting it in a 2nd Gen 2.4-
    1. Would i be right in thinking i need 2" of body lift?
    2. What other parts do i need from the donor vehicle?
    3. Is the toyota gear box upto taking the engine?
    4. Is weight an issue? do i need to uprate the front suspension to cope with it? I'm running wound up torsion bars and standard shocks. So i guess i'll be wanting the uprated torsion bars, and es9000s?
    5. Is the toyota radiator ok for this engine?
    6. What sort of insurance loading am i likely to get? bearing in mind i'm only 23 so my standard insurance is £650
    7. Any issues with the exhaust/manifolds? assuming i need at least custom downpipes to join the manifolds to my current exhaust underneath somewhere
    8. What's a realistic ballpark consumption figure? I know this is a daft question and you don't run a V8 for economy, but my 2.4s only getting 16mpg.
    9. Any other issues i haven't thought of yet?
    10. If in the future i decide to go down the LPG route the v8s going to be the better engine for it but does anyone know what effect LPG has on offroad performance? increased/reduced torque/bhp?
    11. Does anyone know if the 2.4 will go in a zook?
    12. What sort of modifications can you do to a V8?
    And lastly, sorry, no the engine's not for sale, if i don't want it he's keeping it.
    =SOLD UP!=
    No bodylift needed, the V8 is almost half the weight of the 2.4 Surf engine so you'll gain an instant lift at the front.
    MPG will be around the same as you've got now.
    Talk to Vatchman, or use the search button, V8s in Surfs has been discussed constantly for the past three or four weeks!
      no but its easier
      if its EFI all the wiring and ECU
      if the motor isn't to modified
      much lighter, you'll get at least 1" of free front lift with a Rover in there
      none of the petrol rads can cope, deisel ones might be thicker, I always ran a Rangy red
      no idea, probably more than that!
      very few standard manifolds will fit, i think Mark found some, but I always had custom headers
      14-20 depending on right foot
      engine mounts, bellhousing adapter if using Toy gearbox, short (buick) water pump, wiring, and fit of small fitting issues
      Works good on LPG, my Rover V8 run LPG only
      probably
      same as any other motor
        Cheer's guys,
        Tony, could you give a ballpark figure for doing the work? based on it being an EFI lump, and me supplying anything you need from the rangerover. I'm quite happy to sorce other parts aswell, but have no idea on cost for them, so hoping you could give a rough idea?
        reply be email if you would prefer to ian.shrubb@tesco.net
        =SOLD UP!=
          i used the 3.9 ldv ambulance manifolds,but fitted them back to front so that the downpipe exited forward on the o/s and the n/s exited centrally.this set up then clears the steering column.if it were me i would change the injection for carbs.a lot less hassle.http://s86.photobucket.com/albums/k113/vatchman/. just a few pics of the conversion.
          www.overfab.uk
            Do these go straight on or have to be modified?
            Funnily enough i was thinking that, and kinda hoping it's a non EFI lump anyway, i'm going to look sometime this week as i haven't seen it yet.
            =SOLD UP!=
              manifolds will go straight on.i just cut the tops off of the downpipes (the flange and about an inch of pipe)then fabbed up my own exhaust.
              www.overfab.uk
                cheers for that vatchman.
                The more i hear the more tempted i am to have a go at doing it myself, esp. if it turns out to be non-efi
                =SOLD UP!=
                  its no big deal if its efi just remove the inlet manifold and bolt on a carb set up and manifold.
                  www.overfab.uk
