Recall, again!
    Originally posted by RobOnBlackbird
    I'm new to the recall bit, just assumed they would have lost interest in a car of this age and being an import. Do you just ring the local dealer and ask for it to be checked , is the whole process free of charge , thanks in advance,
    Giv em a call @ Toyota GB 01737 367700 & ask for Jayne
    There's always a payback .... You just can't see the surprise Comin !!!!
    Buncefield Burner
      Hi , phoned my local Toyota dealer today regarding recall, They asked my name, address, tel number, then reg no, said they would ring back, just before they hung up they asked chasis number, I started KZN130-900*** before I'd even got to the end of the number they said, no its fine , it definately does not need a recall, have I been fobbed off , or is that right.
      BTW , I tried the toyota GB number given above and it goes straight to fax
      Former owner of 94 Surf SSR-X 3.0 TD
        Sounds like a fob off to me...........
          Try this e-mail address. I got a response from Samantha Betts.
          customer.relations@tgb.toyota. co.uk
            Or give this one a try, Jayne @ Toyota (GB) 01737363633
            Ask for a ref No:
            There's always a Payback .... You just can't tell if or when !!!!
            Buncefield Burner
              They may be right, as not all Surfs are affected by the re-call.
              Check your numbers with this.....
              http://dogandlemon.com/site/japanese...seno=RJ-1281-0
                I've sent an email , thanks for the address, I'll give them a day or so to reply then try the other number if need be,
                Rob
                  copied this from the site you gave, but I had already checked before initial post
                  KZN130-9000000..KZN130-9074514 07/04/1993..09/05/1995 73409.
                  Mine is KZN130-900313*
