hello, i just browsed in (been lurking for a couple of days)... i need some advice because i'm considering buying a Surf or maybe a double cab hilux.
We'd certainly be buying the 2.4 engine, now reading though the other threads it seems this has a bit of a bad reputation with the head. Can someone explain to be exactly what the problem is (warpage, cracking etc) and on which model years the problem is apparent, approx costs to fix? and does this affect only the Surf?
Also which models are the best to go for equipment spec? (im not too fussed about interior trim)
thanks
thanks
as of yesterday.
There is a list kicking around somewhere with the engine numbers that were on the recall - do a search for Heads... though I have no idea if it's complete!
