i must be the biggest fcuk wit thats walking the face of this earth at the mo.earlier in the week i had noticed that the water pump was leaking on the beast.so i ordered a p6 water pump from rimmer bros.it arrived this afternoon,totally different to my original pump.not a problem i thought,so i set about drilling off the new pulley adaptor fitted to the new pump,so that i could press it off and fit my old original pump pulley and mounting.all went really well everything fitted up nicely.then i noticed a piece of the casting on the new pump that was not going to clear the alternator bracket,so on further investigation i decide that this piece of casting was not needed,so i cut it off,i then refitted the pump bolted it up and saw that i had cut too much of the casting off and i had cut into a water way,what a complete to$$er.now i have to unbolt everything and weld it back up at work tomorrow.so i was wondering has anyone else had a visit from the fcuk up fairy this week.
what a retard
thats a good excuse not to do any work at allOriginally posted by vatchmani must be the biggest fcuk wit thats walking the face of this earth at the mo.earlier in the week i had noticed that the water pump was leaking on the beast.so i ordered a p6 water pump from rimmer bros.it arrived this afternoon,totally different to my original pump.not a problem i thought,so i set about drilling off the new pulley adaptor fitted to the new pump,so that i could press it off and fit my old original pump pulley and mounting.all went really well everything fitted up nicely.then i noticed a piece of the casting on the new pump that was not going to clear the alternator bracket,so on further investigation i decide that this piece of casting was not needed,so i cut it off,i then refitted the pump bolted it up and saw that i had cut too much of the casting off and i had cut into a water way,what a complete to$$er.now i have to unbolt everything and weld it back up at work tomorrow.so i was wondering has anyone else had a visit from the fcuk up fairy this week.
Another f**k wit
Had brain storm this week replacing seal on fuel pump, all going well until I decided to remove the bolt above the metal two way banjo joint - didnt need to do this. Problem is I dropped the bolt and cant find it. Looked with torch, took skid plate off from underneath but still cant find the little ba*t*rd. Toyota can supply but £20 + vat. Off tomorrow pm so will have another look. Would have done seal by now but need to find/buy nut.
This nut is driving me nuts!!!!!!!!!!!!
No doubt a back bumperOriginally posted by vatchmanhehe.i dont need an excuse,half day on fridays to.now i wonder what i will be doing tomorrow afternoon
Remember,if you make one before me,you've to make me one as well.
www.scottishmudclub.com for scottish events
