Hi all,
Sorry guys, a non Surf related question
My wife's Astra mists up inside it's windows so you can't see out!
If you start off driving with a clear windscreen, within a mile they will so misted up you can't see out. Even with the heater on HOT (not that the Astra gets very hot) and the fan going full tilt it still does not clear. Only solution is to turn on the Air Con and it clears in seconds
When clear if you turn off the Air Con it mists up again, wots going on?
