since i fitted the heated fuelcat i have been monitoring my mpg and here are the results if you are interested
at a constant 70 in cruise 25.5 to 25.9 on a run my previous was 22.5 ish
thrashing it
(obviously on a private air strip lol) using the power button and generally not giving a fcuk just under 20 when i drove like this before i would get around 17
i go to work for 30 miles on motorway and about 2 miles on a roads and with a mixture of driving (mad & steady 70) will get 22 but if im late and thrashing it at 90 i get just under 20 again
when i have put 75% svo in i get a drop of around 0.5 mpg when i once put 55 ltrs in and 5 ltrs of derv i got the same drop but under 25% svo i dont get a noticable difference
it seems on my car that its the way i drive on the motorway ie speed that makes all the difference apart from the fuelcat that does actually give me around 10% extra
these are the results make of them what you will
edited just to say. . .
ive changed from 28psi in the tyres to 34 psi to stop the wobble while on the motorway
i did this last week but am i right in thinking this won't alter the mpg by any significant amount?
and yes the car seems a lot more stable if a little more hard
thrashing it
(obviously on a private air strip lol) using the power button and generally not giving a fcuk just under 20 when i drove like this before i would get around 17i go to work for 30 miles on motorway and about 2 miles on a roads and with a mixture of driving (mad & steady 70) will get 22 but if im late and thrashing it at 90 i get just under 20 again
its like your not moving
