Converting underslung spare
  • Converting underslung spare
    Does anyone know if it`s possible convert my underslung spare to a rear mounted one (2nd gen)?
    Darran
    Darran
    Yes it is possible, you will need to put strengthening plates in the rear pillar to support the carrier, change the rear lights, move the no plate, and change the old reverse light no plate unit for the catch system for locking the carrier shut, plus on the rear slung carrier type a lot have a switch which opperates a light on the dash to tell you that the spare wheel carrier isn't locked into position, but not all have this
    If it aint broke dont fix it
      Gary, is that all written in one long sentence to get the idea across that it is possible, but is a total pain in the arse, perchance?
      What about just bolting an empty plastic cover on the back? It would look the same but without all that work.
        Sounds like a good option, like it lol
          I wuz looking to do the same thing but it all seems a load of work for not much gain, I know, try changing an underslung spare at 11.oo at night in the pouring rain! (isn't that what the RAC are for??)
            I think the issue is more to do with fitting towbars and being out of the way and easy to get at when offroading
              Recent conversation
              http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=26822
              regards
                Yup, the reason for moving the spare is down to it preventing me fitting the crossmember of the towbar.
                  Oh Nuts, i got thre same tow bar as you so i'm going to have the same probs,
                  i thought someone fitted this bar that had an underslung? i want a rear mounted eventually cos i like the look but cant afford it yet
                    There was someone posted a reply earlier saying he`d fitted his, but was very tight, I`m gonna keep the spare in the car, i`ll have to make some kind of frame and cover for it though.
                      I had mine in the back for ages, it was a bl00dy pain keep takeing it out to get something else in, only took it off to underseal and then did'nt do that either (yet) I thought of makeing a rear carrier that fixes to the tow bar but aint worked that one out yet,
                        Ehhh? I got a towbar and a 33" x 12.5" mud terrain tyre tucked in under there!
                        Mind you...a 2" body lift helps hide the tyre!
                          search is a wonderful thing... I am sure Bundubasher asked for this a while back...
