can anone tell me if its possible to fit the rear slung spare wheel carrier,(tail gate) onto an early gen 2 with an underslung carrier fitted.
Yup, it's possible. However you need to re-inforce the inside of the rear quarter panel to take the extra weight. You'll also need to change the lights clusters, and fit the new number plate holder. That's in addition to getting hold of the carrier etc. Plus wiring for the 'carrier open' warning lamp. etc etc.Paul </Slugsie>
Immortal.so far!
Originally posted by SlugsieYup, it's possible. However you need to re-inforce the inside of the rear quarter panel to take the extra weight. You'll also need to change the lights clusters, and fit the new number plate holder. That's in addition to getting hold of the carrier etc. Plus wiring for the 'carrier open' warning lamp. etc etc.Cutting steps in the roof of the world
Originally posted by vatchmannice one guys ill have a chat with chillit and take a browse on ebay.slugsie do you know how much strenghening needs to be done.
Your best bet is to either speak to someone who's done the job, or get a Surf round that has a rear carrier for a few hours, and dismantle it.
You can convert a non carrier rear tailgate to a carrier rear tailgate. You replace the current numbeplate/reversing light bit with the carrier locking mechanism. I think you probably then just have to drill and bolt the new numberplate thingy on the left of the tailgate.Paul </Slugsie>
Immortal.so far!
done that!easier than changing the lights(and cheaper..) its put a worklight on top of the number plate light holder and use that. the tailgate is basically the same, but it has a bit lump of plastic filling in the recess when the no. plate is. easier to get an entire tailgate. on the trucks that are supposed to have a wheel carrier theres an extra reinforcing plate inside the panel, but its not that strong and i'm sure a man of your calibre can knock something up... there is no wheel carrier warning light on 2nd gens. that'll do for a start..
it's in me shed, mate.
Originally posted by Chillittdone that!easier than changing the lights(and cheaper..) its put a worklight on top of the number plate light holder and use that. the tailgate is basically the same, but it has a bit lump of plastic filling in the recess when the no. plate is. easier to get an entire tailgate. on the trucks that are supposed to have a wheel carrier theres an extra reinforcing plate inside the panel, but its not that strong and i'm sure a man of your calibre can knock something up... there is no wheel carrier warning light on 2nd gens. that'll do for a start..
If it aint broke dont fix it
www.overfab.uk
