There was a TV programme last year called "a 4x4 is born" where they made a hybrid rangerover / 90. I seem to recall they made a rollcage for that. They used a (very fancy) hydraulic pipe bender and a welder.
Parts of your engine go up, stop then go back! Mm!
Blue band or red band steam tube is what you want. Red band has a thicker wall but is a tad heavy. It complies with MSA regs so it must be OK. Make sure you buy British made. There is some imported stuff that satisfies the EU regs but is not as good as the British spec in the QC dept. You will need a 12 Tonne pipe bender too. A little tip (confused the hell outta me at first) is that the dia marked on the dies is the i/d and not the o/d. Good luck!
damn frog islands a no go.i can get my hands on a 12 tonne hydraulic pipe bender so thats not a prob,just knowing where to start and the best point to use to tie into the vehicle frame.
Seeing as you've balled up the concept of keeping it as a sleeper, , why
not make an exo-skeleton?
hi matt.didnt i see a thread on here that had pics of a toyota with an exo fitted to it,not willymammoths.but a black one if i remember correct.anybody.
