Why is it that whenever you fix one problem, another one takes over. Started
off with the new top hose peeing coolant out at the 'stat housing end, so nipped
it up. Then the leak shifts to the new temp gauge sender on the 'stat housing, so
took that out and resealed. Today, it's on the 'stat housing hose to turbo hose
that decides to leak. Wouldn't be so bad, but apart from the rad top hose, the
other two have been fine with no leaks for weeks. I think I'm just having one of
those weeks.
those weeks.
