I know i posted a question on this subject the other day and thanks to Vince and you other guys for your replys, What was bothering me is the capasity figures quoted on that aus tech site vince, roughly 2lt for a drain and refill and 6lt for a "dry" fill, So im thinking if i only drain and refill it im only renewing about a third of the fluid, and the new stuff is "contaminated" with the old stuff still in there, as mine looke burnt i would like to replace the lot otherwise i dont see the point, Did a search and found a reply post by Andy (lucky) whereby you use two buckets and replace the fluid by pumping out the old into one bucket and at the same time draw in the new stuff, this is done through the cooler pipes once the return (pumping) pipe is noted.
So first Q is- is this method ok for the 2.4 (as andy reply was for a 3lt) ?
2nd Q is- this method req about 3 gall of fluid to pump through which is gonna be bl00dy expensive, so if i were to drain it via the plug and then disconnect the coolerpipes and use the engine to pump out the rest and then fill down the dip tube in the normal way will the pump pick it up ok or will it airlock or summat?
3rd and final Q this filter, andy states its behind the sump (inside?) on the 3lt,
is it the same on the 2.4, is it a replaceable one or a magnetic one that just req's a good clean out?
I've just realised perhaps i should have posted this on the 2.4 tech forum but i dont really want to do it all again so very sorry
Cheers Ian
Cheers Ian
Maybe invest in one of these......
That looks interesting, looks like the pumps we used to descale combi's, It just seem's a lot of fluid to do it with the bucket method, i know oil pumps can be a bugger, made that mistake once on my old cresta, did'nt pack the pump with vasaline as i should have and it would'nt pick up, had to drop the sump again and remove it to pack, a right sod of a job, You'd think it would be simple'er to change the atf would'nt you,
Ian
I'm one
soddin surf's! as if i cant find enough to worry about
