emergency brake light stays on
  • emergency brake light stays on
    I'm new to the Hilux community and my new 91 Hilux I just bought has it's emergency brake light staying on while I drive sometimes. I just the brake fluid and there are no issues there. Any advice as to what else I should check out?
    thanks
    e
    You mean the brake warning light on the dash? Check the level of the brake fluid
    and also the connectors on the reservoir.
      thanks
      e
      Hi erik is the float sticking in the fluid reservoir
        "Emergency brake light"? do you mean the fault indicator on the dash?
        Laugh!!! I nearly bought my own beer.
        Paul
          Too slow again
          Paul
            Doesn't that light come on if the pads worn too ?
            Trev
              Nope, they make a squealing noise.
              The brake warning light can be four things,
              Low fluid.
              Float sticking in the reservoir.
              Handbrake (emergency brake) not fully released.
              Vacuum assist (servo) problem.
