hi all. i have a chance of buying some new 18" wheels and tyres for my surf does anyone know if they will fit ok the tyre size what come with the wheels are 285/60/18 ........ graham
18" wheels
Are you sure a 60 profile tyre with an 18" rim will fit???
Bearing in mind, the factory fit is either 75 or 10.5 on a 15" rim....I guess the addition of 1.5" diameter and a slightly smaller profile may even out a bit, it could still be a squeeze, particulaly on steering to lock??? Don't know (but I would consider the cost of mew tyres and as I take my Surf off road a lot, I'd need to know I wouldn't wreck the rims..)Too old to care, young enough to remember
Originally posted by gradoes anyone know if they will fit ok
You need to check how much offset the new rims have.
Offset. If you laid the rim on the floor, face up, offset is the depth to where the bolts fit. This depth can vary significantly between different rims.
Changing the offset will seriously affect lock to lock, rubbing etc etcAnother member of the 'A' team
Those 18 inch tyres have a rolling radius of 399.6, circumference of 2510.76.
My 265/70 16's, which are (pretty much) the max size to go on a standard suspensioned Surf, are 388.7 and 2442.27, so, I reckon that they'll be too big, unless you've got a suspension lift.
And this doesn't take into the offset of the wheels..It just does, OK?
Originally posted by grathanks everyone for your advise i think i will stick with some 15" or 16" after market wheels.. its a shame there no good they looked awsome up against the car....
way, tyre and wheel choices.
