Fitted 33" tyres,but....................
  • Fitted 33" tyres,but....................
    ........................they'r e rubbing in front wheel arch on full lock.Removed mud flaps this helped a little,but still rubbing.
    I have the 2" body lift, 2" rear springs with adjusted torsion bars,is it maybe the torsion bar aint cranked up enough? 33" tyres are on 10" rims and stick out from arches about 2". I'll post some pics once i take them.
    Anyone else had this problem????????
    Cheers.
    www.scottishmudclub.com for scottish events
    No, but our rims are level with the arches, its the extra offset you have thats moving the tyres nearer the bulkhead. Ours is with maxed out HD torsion bars and 1 1/2" of body lift. I had trim the lump that protrudes from the inside of the mud flap and moved the bumper forward 1"
    You need more height, more abuse to the bulhead where its rubbing or less offset on the wheels (assuming you don't have wheel spacers fitted, if so take them off)
      Cheers.
      Gonna try cranking torsion bar up a bit more. Was measuring 34cm before body lift from top of rim to under arch.Hopefully another half inch to gain. Adjusted steering stop bolts as well,not as tight a lock but stops the rubbing for just now.
        since changing the wheels and tyres have you noticed what diffrence there is in the speedo reading?? i do know that the reading will be the same, but the actual speed will differ, have you checked with sat nav or against another car??
        i take it that you did change from stock tyres/wheels?
        CHEERS JOHN................
          My sat nav reads about 5% out even on standard wheels and tyres! Let alone on 33"'s!
          I NEED TO OFFROAD!
            Alright Danno. Got the lift kit on Thursday .Don't know if it was the first or second dispatched one? I'll return the second one when it turns up,cheers
            Pics on another thread.
            http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=25491
              Yeah think i'm going a wee bit faster than what shows on speedo. Not tried against another car or anything yet.
