Expensive MOT.
  • Expensive MOT.
    Just had the Surf MOT'd, bit of a shocker-new exhaust rear and central sections req'd £250.00 and front brake calipers £250.00, and these aren't even genuine Toyota parts, oh and then theres the labour. This is one week after paying £820.00 for new clutch and dual mass flywheel.
    If I start using vegoil, how long will it take me to break even? Hmmmmm.....
    Ant.
    expensive MOT
    Ant send me your private e mail, my mate has just done a conversion to veg oil, i could put you two in touch to chat.
      Have you already paid? If not check Milners.
      Paul </Slugsie>
      Immortal.so far!
        Conversion ??????
        Hippo isn't converted
        Email me if you wish to discuss
        Trev
          Probably referring to a full blown single or dual tank conversion.
            meat or potatoes
            hello mate just joined a little while ago and am interested in becoming a vegie how much would it cost me to convert from a carnivore many thanx wayne
            MOVE IT OR LOOSE IT
              Thinking of full blown veg use or just mixing? You can run on a mix
              without modification. If you're thinking full hog, you'll get an idea on
              the link below.
              http://www.dieselveg.com/products.htm
                Its only fair to mention the reduced mpg on veggie too. I use it sometimes but am always dismayed at how fast the fuel needle falls to the red compared to Texaco's finest.
