Obviously not surf related but can anyone help me with a telephone cable issue I have regarding a BT to RJ11 cable.
Basically I bought a 10m cable to replace an existing 2m cable to wire up a device but the 10m one is wired up like the top example in the diagram below, whereas the original 2m one is wired up like the bottom example below. Suffice to say the device does not work with the 10m cable. so... I guess I need to buy another 10m cable that is wired up like the bottom example (or perhaps like the second example as the two pins I am interested in are connected in the same way) - but what do I look for/ask for when ordering?
The info I have found on the web (such as http://www.pickaxe.demon.co.uk/surftime/wiring.htm) lists 4 ways of wiring but none seem to have a specific name or code or anything! How do you know what type you are buying???
![](http://www.pickaxe.demon.co.uk/surftime/431a-rj.gif)
