Oil Catcher !!!!!
smokey filter
the filter/oil catcher looks the buisness, the smoke you are talking about is probably oil vapour being pushed through the filter. The best way to confirm this is to place a white rag over the filter and go for a blast in the Surf. When you get back, have a look at the rag if it is smoke it will be dry black residue. If it is vapourised oil the rag will feel slimy. I think there is a good chance this is normal, but not having a fancy catcher, I am only guessing.
Originally posted by chasharmanthe filter/oil catcher looks the buisness, the smoke you are talking about is probably oil vapour being pushed through the filter. The best way to confirm this is to place a white rag over the filter and go for a blast in the Surf. When you get back, have a look at the rag if it is smoke it will be dry black residue. If it is vapourised oil the rag will feel slimy. I think there is a good chance this is normal, but not having a fancy catcher, I am only guessing.well pleased with the look of it
so hopefully all is well cheers dave
Originally posted by joker??its from the breather pipe off the engine ,
its to stop oil going into turbo
sh#t what do i know ??Trust your Hound.
RatSport stu cost £60 + i think about £7 for another filter to go on the the turbo
Unit 3
White Hart Road
Plumstead
London
SE18 1DH
United Kingdom
Phone: 020 88544777
Fax: 020 88542404
taliesins this one does away with having anything go to the turboLast edited by joker??; 21 June 2006, 12:08.Only Toyota can get you out of shite
taliesins this one does away with having anything go to the turbo[/QUOTE]
I dont quite understand that, if nothing goes to the turbo why not just disconnect the pipe to the turbo. and have the breather from the engine drain off somewhere, I am new to turbos so do not fully understand. Could you explain?Trust your Hound.
Originally posted by Taliesinstaliesins this one does away with having anything go to the turbo
I dont quite understand that, if nothing goes to the turbo why not just disconnect the pipe to the turbo. and have the breather from the engine drain off somewhere, I am new to turbos so do not fully understand. Could you explain?[/QUOTE]
sorry didnt explain myself properly
still got air filter going into turbo, and have a pipe with air filter where the breather pipe used to go into the turbo (understand you have to have a filter or something to stop sh#t going into turbo)
have a pipe from breather (engine ) into oil catch,if you just have it into engine bay oil fumes will come into car
you are new to turbos !!! i am new to engines ,turbos and anything mechanical lol
there is nothing wrong with the way you have done yours was going the same route but got this idea of vince ie bushwackerOnly Toyota can get you out of shite
Originally posted by joker??RatSport stu cost £60 + i think about £7 for another filter to go on the the turbo
Unit 3
White Hart Road
Plumstead
London
SE18 1DH
United Kingdom
Phone: 020 88544777
Fax: 020 88542404
Stuhttp://www.manicgamer.net
