see attached! still got to wire them up (tomorrow...) but they fit nicely. Couple of infinity 6x9's with inbilt tweeters so should sound good.
Had to cut off the ends of the metal plate beneath the door card and also do a bit of jiggery pokery to get the screws in (drilled holes in the metal chassis) but they fit in nicely, and the window still works no problems. Wiring them in tomorrow should be fun! I intend to use the wiring loom for the rear electrics, or at least come through the same hose.b
i take it you aint watched the footy today,you look as though you have half a diy shop in the back of your truck!
