just had a horrible holiday in Dorset, the only good bit was the weather. On the way home on the M25 the nice policemen clossed it causing my 3hr journey to take nearly 7 , to make it all perfect in about 80 degrees smoke started coming out of the vents when i put the air condirioning on - why is it doing this ???
Scorcher.....broken air con !!
your not kidding - got a mountain of washing to do and the washing machine just blew up, mrs b is not happy AND just checked the air con again now the family are safe and out the way and it seems fine !!! - welcome homeBunkle
Fox Hunting is Dangerous
By the sounds of things, it could have been worse - seen this report relating to the M25 today ?Originally posted by Bunklejust had a horrible holiday in Dorset, the only good bit was the weather. On the way home on the M25 the nice policemen clossed it causing my 3hr journey to take nearly 7 , to make it all perfect in about 80 degrees smoke started coming out of the vents when i put the air condirioning on - why is it doing this ???
TrevLook out Eastbourne, the Pandas are coming !
Filling in for Vince with the links?Originally posted by UDTrevBy the sounds of things, it could have been worse - seen this report relating to the M25 today ?
Trev
Nope, cannot compete with the VinceOriginally posted by MattFFilling in for Vince with the links?
Mind you, if I hadn't of been off today would have been caught in that
TrevLast edited by That Ruddy Squirrel; 9 June 2006, 17:52.Look out Eastbourne, the Pandas are coming !
My air con a couple of times last year put what I thought to be smoke out the centre vents. It worried me the first time, but the second time I ignored it cause it didn't smell, and she hasn't done it since. I thought maybe it was condensed air?Gone from 4x4 to 1x2
Sounds like it's broke!
