see attached! the crossover is in the pocket. sounds much better now... it'll sound even better when I get round to the rear speaker install!
My new front speakers
Originally posted by mootersee attached! the crossover is in the pocket. sounds much better now... it'll sound even better when I get round to the rear speaker install!
Stuhttp://www.manicgamer.net
Originally posted by amethystlooking kinda nice... i am in need of some to fit into the speaker slots already there any ideas what to get for them?
StuI got me a new Surf baby yeah!
Stu
All depends what you want to achieve.
What sort of sound are you after...?
Originally posted by AndyLala2nd Gen's are 4" holes... they have a rather natty vented enclosure around them, so some crossed over 4" co-axials would work rather nice.
so thought i would ask to see if someone has knowledge of them on here... size etc... will prob replace both front and keepa spare//
Just put one of my new (old) front door speakers on, Made the pods before i found out what was behind the card, so they stick out a bit, Have'nt got a pic yet but these are the back ones (they stick out a bit too) Not happy withe the sound as i just connected em to the old speaker wires and these
have a amp thing on each one so perhaps it that, Dont know how to bypass
em cos i know diddley about ICE, The speakers used to be in my sons rover
220 and sounded good in that.Too young to die and too old to give a toss
Ian,
if you take the original box's out, there is a circuit board in there.. You can trace which is power, which is earth and which is signal.
Remove power, and make safe. Bypass internal amp and direct onto the speakers... its not a complicated system.
Originally posted by mooteri had to hack at my door cards to do that... if you wanted to drop some into the dash mount panels then you'd be limited to 10cm's. i wanted more than that, along with some bass (which the door cavity provides) so I went for the door cards. mine are 6.5" woofers.Real trucks don't have spark plugs
Remove power, and make safe. Bypass internal amp and direct onto the speakers... its not a complicated system.Too young to die and too old to give a toss
Originally posted by AndyLalaI have also heard a couple of Surfs with Kicker Competition 4" co-axials in the original locations... just those with a fair bit of welly behind them sounded pretty good...
