could anyone give me a ballpark figure as to what i could be asked to pay for a new camblet+fitting.
cambelt pricecheck
cambelt costs
less than hundred notes for a new fitted cambelt that sounds like good value to me,i will let me other half treat the old truck to a new one with her next pay cheque[i know i'm spoiling her!]
after all its the least she can do after her dog/horse hairs clogged up the rear window assembly.
Originally posted by M35A2Get a genuine Toyota cam belt and buy the tensioner while your at it. The job is easy to do and will take between half and an hour.
this would come in handy for me the next time it becomes due. Thanks in advanceTrust your Hound.
This is how I do it....
Unbolt vacuum hose from across the fan cowl and remove, remove fan cowl, (you can do this without removing the top hose if you're careful) then remove fan.
The above is optional, it just makes life much easier and save struggling to get at things.
Unbolt bolts and two clips that hold belt cover on.
Line up timing marks, remove tensioner.
Check idler bearing for wear (quiet when spun and no wobble). Check tensioner for oil leaks or wear. (You shouldn't be able to push the piston in without a press/vise)
Gently close the tensioner up in press/vice and put a small drill or allen key through hole to keep it closed
Install new belt, then tensioner, pull out drill/allen key.
Turn engine BY HAND one cycle vand check timing marks still line up.
Bolt everything back on, and your done.
There, thats done me out of £50 to fit it!!!!!!
