Originally posted by Tallyman
m.p.g. when towing
Last time I filled up cost me around £55 but that was a couple of months ago, as the beast has been sat on the drive doing nothing for a while. You'll have a 65 litre tank, so even if you run out completely (DON'T OR YOU'LL HAVE PROBLEMS WITH THE FUEL SYSTEM) it should only cost you about £65 to fill up. I've had 29 mpg keeping to about 60 on the M-way but that's unusual as I usually travel at an indicated 80 (but that's only 74 according to the sat-nav). I find it's best to let the car travel at the speed it feels most comfortable at and hang the mpg.Mike G
Originally posted by TJGI got 21mpg towing by Bailey Ranger 420 which is nowhere near 2 ton but it was well frieghted (probably more than it should have been), I had 3 adults (with all theri junk), 3 dogs roofbox with full awning & 2 annexes in and a 75 mobility scooter split between the roof and the boot in the car. I really could not have carried another fag paper. Mind you moving that lot around I kept the speed down to 50-55 and I think it paid back at that sort of MPG.
Did you get your roof bars from Rough trax ? are they any good ? i have been looking for some to go in the rails on the 3rd gen.
Andy
Originally posted by Andy WDid you get your roof bars from Rough trax ? are they any good ? i have been looking for some to go in the rails on the 3rd gen.
AndyParts of your engine go up, stop then go back! Mm!
It supposedly causes the gearbox to act more sporty! It will hold the gears for slightly longer alowing the engine to rev slightly more before changing up, it also allows it to change down sooner. Which I find very usefull as my truck seems to have a hugh flat spot between 40mph to 50mph. If you are gentle with the throttle it will change up normally.
It can effect the MPG, but in my experiance not by much.Gone from 4x4 to 1x2
I know this is an old thread but, I thought i read somewhere that someone had destroyed overdrive while using it while towing! Is this a load of nonsence ?? Whereabout is the temp guage suposse to go upto on the gauge before you could say it is now overheating ??
Originally posted by steved23 mph in France last year towing 1550 kg abbey cruise control set to 2000 rpm approx 63 mph I never take it out of overdrive which is torque converter lockup and will not damage the box.
Originally posted by trev.wwhat does the ect pwr button do exactly?more power,is it reccomended for towing,does it affect m.p.g.?
When towing I keep the ect switched on unless it's a long straight flat run, but if you are going on a road with a few hills keep it on. It holds the vehicle in each of the lower gears a bit longer before changing up, so prevents a lot of hunting up and down the box. On a long uphill run I normally drop out of overdrive for the same reason. I would advise you fit an ATF cooler ASAP if your going to use your Surf as a tow car, it will help to prevent the coolant getting too hot as well as helping the ATF burning. Also an idea to fit an override switch on the electric fan so you can get it turned on in plenty of time for a long uphill run. Keep an eye on the temperature gauge (even on a 3 ltr) and if it all starts to get a bit warm pull over ASAP and let things cool down, keep the engine ticking over and even turn the heater on full to lose the heat a bit quicker. I've fitted a few washers between the bonnet hinges and the bonnet so the rear edge is lifted about half an inch and have found that this also helps remove quite a bit of heat from the engine bay. Next job is to sort out the viscous fan to try and get it to cut in a bit sooner. Oh yes as for MPG when towing!!!!!!!!!!!!!!!!! Don't ask it makes me cry
Spoggle
