Hello
I inspected a 3.0TD series 2 today and took it on a test drive. I have the following questions that I hope can be answered:
Question What is the idle speed for this engine?
It appeared to be around 750rpm. When moving from neutral to drive, the engine management system would compensate for the loading effect (foot on the brake) and still maintain this. The main point of concern is that there was quite a bit of vibration felt on the steering wheel and visible on the instrument binacle. On an earlier test drive of a different vehicle, this had not been evident.
Question Can any 3.0TD owners confirm whether this is true of their vehicle?
Above these rpm's, the vibrations noticeably subside.
Question On 3.0TD, is there are glow plug indicator? If so what does it look like (a coil symbol?) and where is it located?
Question Does it come on for a set period of time for each startup, or is it variable depending on engine temperature?
Thank you in advance.
Mark..
Mark..
