Hi, You probably all know about these but just in case- I got these from the ebay seller i got my gauges from, The green ones for the water temp gauge sender, Just cut the hose slip it in and screw in the sender run a wire from the screw to engine (earth), Comes with hose clips and also in different sizes,
Im gonna use the lower rad hose, The blue one is for oil temp/pressure gauges
and has four tapping for senders and blanking plugs for the ones you dont need, Just remove oil filter, fit this and refit the filter, screw in the senders and your away, There a bit heavy at £12 and £25 respectively but it certainly
a lot easier than hunting around for tees and adaptors and you get a roll of PTFE as well, Just thought i'd mention em, Ian
disco now gone aswell
so i've cocked summat up, Have'nt fitted the boost
