Mot failure
  • Mot failure
    BAD NEWS
    $$$$$$ truck failed its MOT due to excess upper ball joint movement
    anti roll bar bushes, BUT the they also failed it on a worn foot brake rubber
    where the hell do i get one of them! milners or roughtrax dont stock them
    and retest on tuesday morning, any ideas
    Toyota dealers will get them, otherwise find a similer size one from a breakers, or failing that make one from a bit of mud flap or rubber mat and glue it on.
      call toyota mate - its what they are there for.
      pnc number 47121
      part number 31321 - 14020 - manual transmission
      possibly 47121 - 12011 - auto transmission.
        never thought of that
          Sounds a little petty to me did you upset them
          I'd look for a new test centre mate
          xcuse mi spilling kan't phinda dictonnairy
            My thoughts exactly, but I suppose it'a safety issue as it's the brake pedal.
              It does seem petty, but that's the rules..
              Mine passed, but he did have a good look at the rubber. It had a hole in it, but as it wasn't actually split along the vertical length, he classed it as a pass.
              Apparently, it's checked cos if the rubber was split all down one side, the rubber 'could' shift to one side, and when the brake is applied, it 'could' also apply the accelerator.
              Unlikely, I know, but that's why it's classed as a failure.
              Not sure what would happen if you just took the rubber off completely, tho?!
              Oh yeah, and Roughtrax DO sell replacement go-faster pedal sets, if needed!!!
              It just does, OK?
