due to frequent servicing of the 3.0 td , i was thinking about putting a k&n filter into the airbox .anyone have 1 fitted , if yes what was the difference if any in the way the motor ran - thanks
K&n Air Filter
Have a read here....then see if you still want one.
http://www.hiluxsurf.co.uk/forums/sh...26n+Air+Filter
Originally posted by Dog_BookI have a KN fitted.....not like in that post though and its in place of the standard filter so works perfectly
Correction just had a look at mine and it is a Greddy Airinx system not a K&N. (Came with the Truck)Last edited by Taliesins; 13 April 2006, 12:29.Trust your Hound.
Ah ha! This is what you need then......K&N E-2487. http://www.dcdezign.com/details.asp?item=e-2487
Originally posted by internetsurferGREDDI ?? that's an induction kit , i just want a k&n air filter , just like the stock filter.
I am new to both Diesel and Turbos so please bear with meTrust your Hound.
yours is an induction kit - ok if its enclosed from engine temps with a cold air feed going to it , yours at the moment when the engine gets hot will suck in all that hot air which isnt good, cold air is denser and contains more oxygen ,which in turn equals more power and better detonation within the piston chambers.The filter i'm after sits inside the stock air box ( removed from yours ) which receives cold air via a tube leading down to the inner wing or somewhere similar away from engine heat, the k&n performance filter isnt made of paper and wont clog as easily therefore choking the engine of vital air/oxygen .It is also re usable upto 1 million miles .so a little of the expence is gone out of servicing , yes 6 quid for a filter , but replacing it time and again = 60 to 100 quid.
your motor looks to have a catch can built into it too , this catches c rap from the breathers as it passes the can , maybe you should check it , it may need emptyingLast edited by internetsurfer; 13 April 2006, 20:02.
