Hi all any ideas on an Oil leak I have, (it appears on the head of the bolt heads that hang upside down) I believe it's part of the Oil Filter Houseing on driverside of the Engine.
1. Do the Bolts have some sort of rubber seals or washers that can be replaced ?
2. Can these bolts be removed safely without any problems to replace Seals/ washers ?
Hope these pics Help !
There's always a Payback.... You just cant see it Comin !!!!!
